- 19
- 2007-1-25
发表于 2010-4-6 11:11:07
来自 广东深圳
手册上写得很清楚了:
Click the Restart button on the Main toolbar or choose Restart from the Solve menu. Either action restarts the analysis using the current solution as an initial value, the current values of variables not solved for, and the linearization point. In other words, the solver operates as if you had selected the Current solution option in the Solver Manager dialog box. Restarting the solution process is helpful, for example, for using a stationary solver to first compute a good initial value for a nonlinear or transient analysis, or for interrupting and continuing a transient simulation. For a transient analysis that is not time invariant (where there is an explicit dependence on time in the equations), note that you probably want to change the time list in the Times edit field before restarting the solver. |
